Can I get the QMI driver for The EG25 Module.
Currently having an issue where I get signal as 0% even though modem, antenna and sim works okay in another version of Linux.
Kernel Version is 5.4.0-1069-raspi
My email is scbd2019@gmail.com
Cheers
General | path: /org/freedesktop/ModemManager1/Modem/0
| device id: d2cfbcfddcb24a4529910d014e5344c55537e053
Hardware | manufacturer: QUALCOMM INCORPORATED
| model: QUECTEL Mobile Broadband Module
| firmware revision: EG25GGBR07A08M2G
| carrier config: ROW_Generic_3GPP
| carrier config revision: 05010820
| h/w revision: 10000
| supported: gsm-umts, lte
| current: gsm-umts, lte
| equipment id: 860195055053125
System | device: /sys/devices/platform/soc/fe980000.usb/usb1/1-1/1-1.4
| drivers: option, qmi_wwan
| plugin: quectel
| primary port: cdc-wdm0
| ports: cdc-wdm0 (qmi), ttyUSB0 (qcdm), ttyUSB1 (gps),
| ttyUSB2 (at), ttyUSB3 (at), wwan0 (net)
Status | lock: sim-pin2
| unlock retries: sim-pin (3), sim-puk (10), sim-pin2 (3), sim-puk2 (10)
| state: enabled
| power state: on
| signal quality: 0% (cached)
Modes | supported: allowed: 2g; preferred: none
| allowed: 3g; preferred: none
| allowed: 4g; preferred: none
| allowed: 2g, 3g; preferred: 3g
| allowed: 2g, 3g; preferred: 2g
| allowed: 2g, 4g; preferred: 4g
| allowed: 2g, 4g; preferred: 2g
| allowed: 3g, 4g; preferred: 4g
| allowed: 3g, 4g; preferred: 3g
| allowed: 2g, 3g, 4g; preferred: 4g
| allowed: 2g, 3g, 4g; preferred: 3g
| allowed: 2g, 3g, 4g; preferred: 2g
| current: allowed: 2g, 3g, 4g; preferred: 4g
Bands | supported: egsm, dcs, pcs, g850, utran-1, utran-4, utran-6, utran-5,
| utran-8, utran-2, eutran-1, eutran-2, eutran-3, eutran-4, eutran-5,
| eutran-7, eutran-8, eutran-12, eutran-13, eutran-18, eutran-19,
| eutran-20, eutran-25, eutran-26, eutran-28, eutran-38, eutran-39,
| eutran-40, eutran-41, utran-19
| current: egsm, dcs, pcs, g850, utran-1, utran-4, utran-6, utran-5,
IP | supported: ipv4, ipv6, ipv4v6
3GPP | imei: 860195055053125
| enabled locks: fixed-dialing
| registration: idle
3GPP EPS | ue mode of operation: csps-2
SIM | primary sim path: /org/freedesktop/ModemManager1/SIM/0
