Hello, what is behavior of AT+QISEND command? I tried to send data through this command. I’m connected to TCP server successfully but not sure how to use this command properly. Will UC wait until I send 0x1A or length reach? or it will timeout? Manual didn’t say it clearly.
Hi mangmuang,
I found the UGXX module to change the command instructions, I think you can try to refer to, I hope it can help you.
Quectel_WCDMA_UGxx_TCPIP_AT_Commands_Manual_V1.4.pdf (1.6 MB)
thanks
