When updating firmware of BG770 via debug uart, i’m noticing a application timeout of about 500 seconds.
By changing the UART speeds i’ve found that the application always timeout at ± 500 seconds of execution, and different percentage of firmware loaded. I’m unable to complete the firmware update.
Does anyone else have same problem?
i’m sorry haven’t given any feedback; I solved the problem by adjusting the var “Max_DL_Time” in file “MainConfig” of the software. As i knew (by testing) the timeout is 500sec, found it and changed it for a bigger value.
3M baudrate is impossible in my setup. As so, a change in the timeout is a must
