I am trying to upgrade AG550Q with QFirehose.I have some questions
With Upgrade Firmware Locally. QFirehose will run in Linux, right?
With Upgrade Firmware Remotely. Will “QFirehose -p 9008” run in AG550 and Will “./QFirehose -f AG550QEUABR03A03M8G_OCPU_01.001V01.01.001V01 -p 192.168.1.1:9008” run in UBUNTU ???
Thank you
Dear Customer,
QFirehose can run in Linux, “./QFirehose -f DirectoryOfFirmware” is the correct command to proceed.
Please make sure the connection is active if you were working remotely.
BR,
Louis
Yes, “QFirehose -p 9008” will run in AG550, execute ./QFirehose -p 9008, and then you can execute ./QFirehose -f AG550QEUABR03A03M8G_OCPU_01.001V01.01.001V01 -p 192.168.1.1:9008 to upgrade.
Please make sure the connection is active.
BR,
Louis
So what is the difference between these 2 ways? When the upgrade package is saved on Linux
One for local, the other for remote. If both methods are available on your side, the local upgrade method is suggested.
BR,
Louis
remotely upgrade method is a alternative solution for local upgrade method ?
Regrad
Nam
Does QFirehose support AG215?
Regard
Nam
QFirehose is competible to Quectel LTE&5G module, it supports AG215 module.
BR,
Louis
What is the difference between the two versions of QFirehose available in the Android directory??
Could you please post the 2 versions here?
BR,
Louis
arm64-v8a and armeabi-v7a
Regard
Nam.
arm64-v8a is for 64bit Andriod system, and armeabi-v7a is for 32bit.
BR,
Louis
For each system, these two methods are not always available, right?
Regard
Nam
Which 2 methods you are referring to?
The method for using the tool is the same.
BR,
Louis
How does QFirehose in Android?
Regard
Nam.
