Hi, I use a Quectel SC600T-EM on my SMART-EVB-G2_V1.2. I have already installed the drivers and some at commands work, but when I run ‘AT+QENG=?’ command I receive an ERROR. I have this result also with other commands (like ‘AT+QNWINFO=?’, ‘AT+QPING=?’ and others). After some research on Forums, I have read that it might be a firmware update issue. So I ask if you can send me the latest firmware for my setup. Thanks in advance.
My firmware is:
If not see the image, the firmware version is: SC600YEMPAR06A04
Below a part of the log:
[2023-07-19_15:27:00:485]OK
[2023-07-19_15:27:02:554]AT+CREG?
[2023-07-19_15:27:02:554]+CREG: 1,1
[2023-07-19_15:27:02:554]OK
[2023-07-19_15:27:08:752]AT+CGREG?
[2023-07-19_15:27:08:752]+CGREG: 1,0
[2023-07-19_15:27:08:752]OK
[2023-07-19_15:27:10:999]AT+CEREG?
[2023-07-19_15:27:10:999]+CEREG: 1,1
[2023-07-19_15:27:10:999]OK
[2023-07-19_15:27:27:002]AT+QENG=?
[2023-07-19_15:27:27:005]ERROR
[2023-07-19_15:27:33:632]AT+QENG=“servingcell”
[2023-07-19_15:27:33:632]ERROR
[2023-07-19_15:27:41:239]AT+QENG=“neighbourcell”
[2023-07-19_15:27:41:239]ERROR
I trust in your answer. Best regards
Alessio
