Hi i am able to register the jio or private network but in tool network registration status showing not registered but by using at command i am able to see the network as registered.
please refer attached picture and at command result
[2024-05-07 16:53:13:181_S:] ATI
[2024-05-07 16:53:13:256_R:] ATI
[2024-05-07 16:53:13:256_R:] Quectel
[2024-05-07 16:53:13:256_R:] AG521REU
[2024-05-07 16:53:13:256_R:] Revision: AG521REUAAR01A01M4G_OCPU
[2024-05-07 16:54:49:185_R:] AT+CGMR
[2024-05-07 16:54:49:185_R:] AG521REUAAR01A01M4G_OCPU
[2024-05-07 16:54:49:185_R:] OK
/* Use AT+COPS? to query current Network Operator */
[2024-05-07 16:42:47:320_S:] AT+COPS?
[2024-05-07 16:42:47:409_R:] AT+COPS?
[2024-05-07 16:42:47:409_R:] +COPS: 0,0,“Open5GS”,7
[2024-05-07 16:42:47:409_R:] OK
[2024-05-07 16:44:05:887_S:] AT+CREG?
[2024-05-07 16:44:05:967_R:] AT+CREG?
[2024-05-07 16:44:05:967_R:] +CREG: 1,0
[2024-05-07 16:44:05:967_R:] OK
[2024-05-07 16:44:21:452_S:] AT+CGATT=1
[2024-05-07 16:44:21:532_R:] AT+CGATT=1
[2024-05-07 16:44:21:532_R:] OK
[2024-05-07 16:44:43:012_S:] AT+CGPADDR
[2024-05-07 16:44:43:101_R:] AT+CGPADDR
[2024-05-07 16:44:43:101_R:] +CGPADDR: 1,“192.168.100.2”
[2024-05-07 16:44:43:101_R:] +CGPADDR: 2,“192.168.101.2”
[2024-05-07 16:44:43:101_R:] +CGPADDR: 3,“”
[2024-05-07 16:44:43:101_R:] +CGPADDR: 38,“”
[2024-05-07 16:44:43:101_R:] +CGPADDR: 39,“”
meanwhile ping test command is not working
[2024-05-07 16:52:07:035_S:] AT+QPING=?
[2024-05-07 16:52:07:114_R:] AT+QPING=?
[2024-05-07 16:52:07:114_R:] ERROR
[2024-05-07 16:52:10:844_S:] AT+QPING?
[2024-05-07 16:52:10:954_R:] AT+QPING?
[2024-05-07 16:52:10:954_R:] ERROR
please help me to resolve the issue
I am sorry that the QNavigator do not update any more.
The QNavigator only support Quectel standard 4G modem. It even do not support the Quectel 5G modem.
hi @Bean.Wang-Q my module is support LTE i am a connecting lte network only
[2024-05-07 17:14:13:213_S:] AT+qeng=“seRVINGCELL”
[2024-05-07 17:14:13:323_R:] AT+qeng=“seRVINGCELL”
[2024-05-07 17:14:13:323_R:] +QENG: “servingcell”,“NOCONN”,“LTE”,“FDD”,1,01,19B01,1,3150,7,3,3,1,-112,-6,-88,16,255,-32768,17
[2024-05-07 17:13:36:018_S:] AT+qnwinfo
[2024-05-07 17:13:36:097_R:] AT+qnwinfo
[2024-05-07 17:13:36:097_R:] +QNWINFO: "FDD ",“101”,“LTE BAND 7”,3150
please let me know any software latest upgrade i need to do
The QNavigator will not have any new release any more.
You can check the
AT+CREG?
AT+CGREG?
AT+CEREG?
AT+C5GREG?
Any new software release for my quectel module .
please find below output
[2024-05-07 17:34:34:772_S:] AT+CREG?
[2024-05-07 17:34:34:866_R:] AT+CREG?
[2024-05-07 17:34:34:866_R:] +CREG: 1,0
[2024-05-07 17:34:34:866_R:] OK
[2024-05-07 17:34:50:123_S:] AT+CGREG?
[2024-05-07 17:34:50:218_R:] AT+CGREG?
[2024-05-07 17:34:50:218_R:] +CGREG: 0,1
[2024-05-07 17:34:50:218_R:] OK
[2024-05-07 17:34:54:353_S:] AT+CGREG?
[2024-05-07 17:34:54:448_R:] AT+CGREG?
[2024-05-07 17:34:54:448_R:] +CGREG: 0,1
[2024-05-07 17:34:54:448_R:] OK
[2024-05-07 17:35:10:973_S:] AT+CEREG?
[2024-05-07 17:35:11:085_R:] AT+CEREG?
[2024-05-07 17:35:11:085_R:] +CEREG: 0,1
[2024-05-07 17:35:11:085_R:] OK
[2024-05-07 17:35:21:420_S:] AT+C5GREG?
[2024-05-07 17:35:21:500_R:] AT+C5GREG?
[2024-05-07 17:35:21:500_R:] ERROR
sorry i am new for quectel AT command. abnormal means network is not stable or some other issue.
what is the excepted result i need to get AT+CREG?
AT+CGREG?
is 3GPP standard AT command.
thankyou @Bean.Wang-Q i have one doubt i need to set ipv4 only for my commercial network is it possible. I tried below command but getting error
[2024-05-07 17:58:12:160_R:] OK
[2024-05-07 17:59:21:462_S:] AT+Cgdcont=1,“IPv4”,“internet”,“0.0.0.0”,0,0,0,0
[2024-05-07 17:59:21:551_R:] AT+Cgdcont=1,“IPv4”,“internet”,“0.0.0.0”,0,0,0,0
[2024-05-07 17:59:21:551_R:] ERROR
First, the AG521REUAAR01A01M4G_OCPU is not a standard modem. It is open firmware for automative.
Some command might not support.
Secondly, you should try
AT+CGCONT?
AT+CGDCONT=1,“IPV6”,“internet”
AT+CGDCONT do not support to set username and password and auth type.
HI @Bean.Wang-Q i tried with jio network getting error
[2024-05-08 10:56:18:522_S:] AT+CGCONT?
[2024-05-08 10:56:18:601_R:] AT+CGCONT?
[2024-05-08 10:56:18:601_R:] ERROR
[2024-05-08 10:56:30:203_S:] AT+CGCONT?
[2024-05-08 10:56:30:297_R:] AT+CGCONT?
[2024-05-08 10:56:30:297_R:] ERROR
[2024-05-08 10:56:48:387_S:] AT+CGDCONT=1,“IPV6”,“jionet”
[2024-05-08 10:56:48:483_R:] AT+CGDCONT=1,“IPV6”,“jionet”
[2024-05-08 10:56:48:483_R:] ERROR
[2024-05-08 10:56:54:405_S:] AT+CGDCONT=1,“IPV4”,“jionet”
[2024-05-08 10:56:54:496_R:] AT+CGDCONT=1,“IPV4”,“jionet”
[2024-05-08 10:56:54:496_R:] ERROR
Seems that the AT command is not supported.
Please check wether
AT+CGCONT=?
supported?
You can try AT+QICSGP to set APN, if it also not supported, I am afraid it is opensolution you have to set the APN inside the modem and set the APN with Quectel API.
Please check
AT+QICSGP=1
HI @Bean.Wang-Q i am getting error for two commands
[2024-05-08 11:05:34:162_S:] AT+CGCONT=?
[2024-05-08 11:05:34:257_R:] AT+CGCONT=?
[2024-05-08 11:05:34:257_R:] ERROR
[2024-05-08 11:05:49:501_S:] AT+QICSGP=?
[2024-05-08 11:05:49:612_R:] AT+QICSGP=?
[2024-05-08 11:05:49:612_R:] ERROR
[2024-05-08 11:05:52:093_S:] AT+QICSGP=1
[2024-05-08 11:05:52:191_R:] AT+QICSGP=1
[2024-05-08 11:05:52:191_R:] ERROR
i need to set apn in qnavigator tool right in setting-apn
or any other way to set apn
siva307:
AG521R
it is not a standard 5G modem. It is Automative module. So some common AT command is not supported.
thankyou @Bean.Wang-Q i am testing LTE(4g) only as per data sheet this modem supports LTE
i added apn in tool but still no luck.
Sorry.
Please try
AT+CGDCONT?
