PWRKEY voltage is too low
I pulled down the PWRKEY pin to GND with a 1k resistor, and when I powered the module, the PWRKEY pin voltage was 0.18V. Due to this, the system is not working correctly. How can I resolve this issue?
because you pulled down the PWRKEY pin to GND with a 1k resistor,This PWRKEY voltage must be very low.Please tell me what module you are using. Some modules cannot be directly pulled down with resistors
