Hi @Louis.Huang-Q. I have a question. Can you help me?
Before, AG550 connect to PC(com port) ,so I can use adb in win or linux to push the compile file to AG550 and run it
Now, AG550 connect to Soc(8295), Do you know How i can push and run compile file but I don’t need to connect to PC? (PC connect to 8295 with com port)
Regards
Nam
From SoC end, you can also enable ADB for the same function, it works the same, but USB connection is still needed. Please refer to Quectel_AG55xQ&AG57xQ_Series_QuecOpen_USB_Configuration_Guide_V1.0 for details and contact your agent for this document.
BR,
Louis
@Louis.Huang-Q You mean that in Soc can use adb same PC but AG need to connect SOC with com port, right ?
Regards
Nam
@nam_ph_m From VuC point of view, USB port needs to be connected to PC, once the USB configuration(SDK) is set, you can control AG550 from PC via ADB.
BR,
Louis
@Louis.Huang-Q Can i do the same things in SOC?
Regards
Nam
It works the same in command line.
BR,
Louis
