Hello I’m working with BG950A-GL,
Can someone explain what’s happening after “PSM POWER DOWN” URC is received?
From my measurement current consumption is reduced to about 33µA for about 5sec,
then some bust occurs for about 2s and then ultra low current consumption is reached (less than 3µA).
Is this documented somewhere? Are timings and current burst always the same?
(I also noticed a bug: if a reset pulse occurs before entering PSM, the mysterious current burst after “PSM POWER DOWN” occurs but is way shorter and current consumption stays around 30µA)
Any idea?
Thanks you,
Thomas
