Hi Quectel Support and Community,
I am currently working with the LC29HEA module to set up a local RTK Base Station. I have a few questions regarding the logical workflow to follow after a Survey-In process to ensure the base is operating correctly.
1. Survey-In Result persistence: After sending $PQTMCFGSVIN,W,1,300,2,0,0,0*23, the Survey-In starts and eventually reaches status 2 (Success) in $PQTMSVINSTATUS. However, when I query the configuration with $PQTMCFGSVIN,R, the coordinates often return as 0.0000,0.0000,0.0000.
- Does the LC29HEA automatically “transfer” the Survey-In results to the Fixed Position registers?
- Or must I manually parse the X, Y, Z from the status message and re-inject them using
$PQTMCFGSVIN,W,2,...?
2. Viewing the “Finalized” Coordinates: Is there a specific command to see the reference coordinates currently being used by the RTK engine to generate RTCM messages, other than the fluctuating values in the $PQTMSVINSTATUS message?
3. Professional Command Sequence: What is the recommended “Pro” sequence of commands for a field deployment where I don’t have a PC? My current plan is:
$PQTMCFGSVIN,W,1,300,2.0,0,0,0*3F(Start Survey-In)- Monitor
$PQTMSVINSTATUSuntil status is2. - (Optional?) Re-inject coordinates in Mode 2 (Fixed).
$PQTMSAVEPAR(To save to Flash).
Is this correct, or am I missing a step to ensure the RTCM output (1005, 1074, etc.) starts immediately with the calculated position?
Module Info:
- Model: LC29HEA
- Firmware: [22:47:15.340 Uart Tx:0015 B] $PQTMVERNO58[22:47:15.370 Uart Rx:0055 B] $PQTMVERNO,LC29HEANR11A03S_RSA,2023/10/31,16:52:142B
Thanks for your help!
