We are trying to perform read/write operations on the UART of the BG95-M3, and the strategy we are following is as follows:
We are using UART 0 → Tx = Pin 23. Rx = Pin 22.
baudrate, databits, parity, stopbits, flowctl = 115200, 8, 0, 1, 0
uart0 = UART(UART.UART0, baudrate, databits, parity, stopbits, flowctl)
- We open the UART with the function
uart0.init(baudrate, databits, parity, stopbits, flowctl). - We add the callback to the UART.
- We perform read/write operations.
- We close the UART with
uart0.close().
This process is done every minute, although the time is configurable, ranging from a few seconds to several minutes.
The issue occurs when, after a considerable amount of time (2-3 hours), the initialization line throws the following error:
UART(0) init fail.
I am testing without closing the UART using the uart0.close() instruction, i.e., we keep it open the whole time, and it has been running for a full day without crashing. However, the consumption is much higher, around 12 mA, so we would prefer to use the strategy of opening/closing the UART when needed, with a consumption of around 3/4 mA.
Why is this problem happening?
Is there any limitation on the number of times we can initialize/close the UART process, or could it be related to how Quecpython handles resource release when executing uart0.close()?
