We are using the AT+QCOPS command.
We do not seem to see 4G operators when we issue AT+QCOPS=7,0
We do see the 4G operators when we issue an AT+QCOPS=7.1 scan (which takes much longer)
The “7” should indicate we are scanning all bands i.e. 2G+3G+4G we understand.
Can you explain why this is the case? Thanks, Alex
Hoping that a fix can work
Can somebody from Quectel comment on whether this is an issue with the QCOPS command please.
And where can we obtain the 06 (and 04 ideally) firmware to test in an EG91 modem? Thanks.
Presumably we can do the update with QFlash?
A colleague has verified that A06 also doesn’t work for him.
Quectel advised us to use QCOPS and it doesn’t work.
Can SOMEBODY please respond as a matter of urgency.
