I am trying to make M66 OpenCPU as ModBus Master device, I want to control pin of SP3485 pin which is connected to GPIO of M66,
while trying to read status of UART3 whether all data is sent out or not, I am calling Ql_UART_GetOption this function with UART_TX_BUF_SEND_OUT as parameter, I am getting always -10000 response that is Ql_RET_NOT_SUPPORT,
Is there any example of this Ql_UART_GetOption function?
below is my code:
void waitTillSendDataOut(void)
s32 ret_val = 0;s32 count = 0;
u64 prev_millis = Ql_GetMsSincePwrOn();
while((Ql_GetMsSincePwrOn() - prev_millis) < 20)
count++;
ret_val = Ql_UART_GetOption(UART_PORT3,UART_TX_BUF_SEND_OUT, NULL);
APP_DEBUG(“Data Sent Status:%d Count:%d\r\n”, ret_val,count);
if(ret_val == QL_RET_OK)
APP_DEBUG(“Data has been sent out\r\n”);
break;
The API Ql_UART_GetOption exists in the SDK, but this API is not actually implemented in the kernel, so querying in this way is not supported, and -10000 will be returned when used, and there is no related example.
I’m trying to implement the same funcionality and as far i understand there is no way to figure out when all data have been transmited, as there is neither a callback, neither an event. Hardware flow is also impossible to use, as RTS is input, i.e. uses legacy HW flow. Please Quectel, add support for this!
@proembsys
I suggest the following method to control the direction pin, which i have not yet tested.
Use GPIO for that purpose. Use the same function, but with argument UART_TX_BUF_LEFT_ROOM - it will return how many bytes are available in the TX fifo.
