Problem in receiving SMS EC 200U-CN AC
hello,
when i am sending sms to ec200u-cn module i cant receive automatically SMS if run AT+CMGL=“ALL” this command then i get, but without run command also we get notification or receive SMS
AT+CMGL="ALL" is a text-mode command. What mode does AT+CMGF? say you are in?
[2024-09-07 11:09:16:273_R:] OK
[2024-09-07 11:11:37:134_S:] ATI
[2024-09-07 11:11:37:194_R:] ATI
[2024-09-07 11:11:37:194_R:] EC200UCNAAR03A03M08
[2024-09-07 11:11:37:194_R:] OK
[2024-09-07 11:23:17:071_S:] AT+CMGF?
[2024-09-07 11:23:17:148_R:] AT+CMGF?
[2024-09-07 11:23:17:148_R:] +CMGF: 0
[2024-09-07 11:23:17:148_R:] OK
That’s PDU-mode. The list command for that is AT+CMGL=4
AT+CMGF=1 will put the modem into text-mode, where AT+CMGL="ALL" is correct.
Quectel EC20 LTE Module doesnt show me incoming call or sms( notification)
if i execute AT+CMGL="ALL" this command i can see all incomming sms but i need to see automatically sms
Do you want them to appear as unsolicited results as they arrive ?
What does AT+CNMI? return?
yes
[2024-09-07 14:39:34:302_R:] OK
[2024-09-07 14:39:36:871_S:] AT+CNMI?
[2024-09-07 14:39:36:976_R:] AT+CNMI?
[2024-09-07 14:39:36:976_R:] +CNMI: 2,1,0,0,0
[2024-09-07 14:39:36:976_R:] OK
Do you want SMSs to appear as unsolicited results as they arrive?
What does AT+QINDCFG="smsincoming" return?
thank you sir i solved this problem
Please share the solution which worked for you.
hi , i am working on the ec200u eu , i trying to send long sms message with UCS2 format , i can send short message using ql_sms_send_msg() function but it not work for long message.
