Hi I have a private Nokia network Band n40 with 20Mhz. PMLN is 99970. I perfomed many tests and we cannot see the network. Should I perform some special action for searching 999 MCC networks?
Kind regards
Kind regards
Which module did you use?I need to check. Did you configure APN during your test?
Hello, Try configuring your device to manually search for networks and see if it picks up the 999 MCC. If not, there could be compatibility issues with your device or your private network might not be properly configured. Consult with your network provider or device manufacturer for further assistance.
The problem is solved. The radio was configured as Release 16 and no information was shown in the modem about that Release. Now we have changed to Release 15 and it is working.
Thanks for your support
