I’m working on the Quectel L26-T GNSS module and I have few doubts regarding configuration of the same.
1/ Does the module (L26-T) support AT commands to obtain particular NMEA message sentences?
2/ Can I directly configure the PPS manager to generate PPS signals using PSTM commands or any other settings?
3/ Should I save and reset the module to retain the configuration in case of PSTMPPS commands?
4/ While configuring PPS manager should I disable the PPS and then configure?
I’m able to get the GPS parameters using libgps API’s.
Is it possible to send the commands to gpsd using gps_send() API from libgps?
How should be the command format?
Does it support wire-protocol commands to be send to the gps deamon?
Sorry for the late reply.
No matter what method is used, as long as the module’s serial port can receive it.
For the command format, please refer to chapter 2.3 of the protocol document.
