Hello i have question about PPP with module of m66 . How could i use this module for PPP connection with mcu? İ could connect Via linux embedded there is no problem . i’d like to learn connection PPP Via mcu
regards
as Linux …
you need TCP/IP stack + ppp support
example: https://www.oryx-embedded.com/cyclone_tcp.html
res = AT_Send("ATDT *99***1#\n", NULL, NULL);
example (cyclone)
int PPP_Init(void) {
error_t error = NO_ERROR;
pppGetDefaultSettings(&pppSettings);
pppSettings.interface = interface;
pppSettings.accm = 0x00000000;
pppSettings.authProtocol = PPP_AUTH_PROTOCOL_PAP | PPP_AUTH_PROTOCOL_CHAP_MD5;
error = pppInit(&pppContext, &pppSettings);
if (error) {
TRACE_ERROR("ERR: pppInit()\n");
return error;
error = netSetInterfaceName(interface, "ppp");
if (error) {
TRACE_ERROR("ERR: netSetInterfaceName()\n");
return error;
error = netSetUartDriver(interface, &uDriver); // LINK DRIVER
if (error) {
TRACE_ERROR("ERR: netSetUartDriver()\n");
return error;
error = netConfigInterface(interface);
if (error) {
TRACE_ERROR("ERR: netConfigInterface()\n");
return error;
return error;
int PPP_Connect(void) {
pppSetTimeout(interface, 10000);
pppSetAuthInfo(interface, gsmConfig()->apnUser, gsmConfig()->apnPass); //Set username and password
ipv4SetHostAddr(interface, 0);
ipv4SetDefaultGateway(interface, 0);
ipv4SetDnsServer(interface, 0, 0);
ipv4SetDnsServer(interface, 1, 0);
error = pppConnect(interface);
if (error) {
TRACE_ERROR("ERR: pppConnect()\n");
return error;
TRACE_INFO("PPP CONNECT\n");
//TRACE_INFO("ELAPSED: %d sec\n", GetTickMs() / 1000);
return error;
Could this code ll work in smt32 or in atmel mcu etc.?
I paste you link - Read
LWIP support ppp too
Thank you . İm going to try lwip library and write results here.
We are able to connect Quectel BG95, connecting lwip over pppos.
Following:
Regards.
