I read on specification specification v2.0 that some GPS modules can power off / stand-by with PMTK161 command. stand-by = power off - wake with any command.
But on a document on another site with version 1.1 the commamd PMTK161 is absent.
Does the L76K supports standby / power off command? Maybe I will need a firmware update?
Thank you!
Hi Clavisound,
Please double check the model mark on module shielding case. The protocol specification you refered to is not feasible for L76K. I will send you related document via message.
L76K is a ROM base module, which means it doesn’t have a firmware.
Best regards.
L76K supports Standby mode and Backup mode for power sensitivity application.
Thank you for the clarification.
I suppose this is the source of information.
