OpenCPU Base firmware for EC25-E
Hello I have the following version of the Open CPU SDK: EC25EFAR06A12M4G_OCPU_20.002.20.002_SDK.tar.bz2 could you kindly provide the matching base firmware package I guess is the EC25EFAR06A12M4G_OCPU_20.002.20.002.zip if it is possible , could you provide those 2 document :“Quectel_WCDMA&LTE_Linux_USB_Driver_User_Guide” and “KBA_QuecOpen_Download_Guide” ? Thanks a lot for the support,
Regards Americo
Hi Americo,
The original firmware package is usually provided with SDK together. Where did you get the SDK, please check with the same source. About documents, I share via mail. Please check.
Hello Rodney, when I received the sdk from quectel the opencpu base firmware was missing. Can you please send it ? I checked the package I got from quectel carefully but I do not have the base firmware. I hope you can help me. Thanks a lot
Is version information correct? I do not find this version. Additionaly, there is new SDK version. Please contact Quectel local support resource to get it. We cannot share SDK on forum, sorry about that.
Yes, the version is correct the SDK filename is EC25EFAR06A12M4G_OCPU_20.002.20.002_SDK.tar.bz2 should be from 2021
