I get open cpu sdk for mc60 and install arm gcc
now wen I run make in cmd promp I get follwing error in build log.txt
/usr/bin/sh: -c: line 1: syntax error near unexpected token (m' /usr/bin/sh: -c: line 1: if not exist build\gcc (md build\gcc)’
make.exe[1]: *** [CreateDir] Error 258
make: *** [all] Error 2
what is the solution to compile and build.
Hi
Check whether you have installed the correct compilation environment, I do not have the permission to release the sdk compilation environment, you can contact us fae to obtain the compilation tool, check whether it is consistent with your installation
