Hello, can I get the old firmware version L76NR02A07S for this module? The current firmware is L76NR14A01S. The module itself works, displays the location in QGNSS, and everything is fine. There is a communication problem between the GPS module and the navigator’s microcontroller. I have set the same settings as for the previous module (satellites appear and then immediately disappear). Therefore, I want to try flashing the new module with the old firmware from 2016. I use Google Translate, so there may be some inaccuracies.
Thanks.
