Hi Team,
We are using Quectel EM06-A module for LTE interface. We are facing problem to get LTE interface.
We are using quectel-pppd scripts to connect LTE interface.
I am attempting to connect using the Kajeet SIM card. I am trying to change APN settings by using below command:
- AT+QICSGP=1,1,“Kajeet”,“kajeet”,“”
Once above command is executed LTE interface is not coming up.
I am using context id 1 to set APN settings.
Also, I have tried below command to check activated context id:
- AT+CGACT?
+CGACT: 1,0
+CGACT: 2,0
+CGACT: 3,1
+CGACT: 4,0
It is showing activated context id is 3.
Is there any default context id settings where I need to apply new APN settings.
Is there any command sequence is necessary which I need to follow to get LTE interface up if I change any configurations?
Thank you…!!!
Regards,
Shabana Mulani.
Hi @shabana.mulani
Can you use AT+CGDCONT? Command query apn Settings, if the sim card operator requires the third route as the default bearer, apn needs to be configured in the third route, you can try.
Hi Team,
We are using a network of Verizon network provider.
Please see the below output for AT+CGDCONT? command:
AT+CGDCONT?
+CGDCONT: 1,“IPV4V6”,“”,“0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0”,0,0,0,0
+CGDCONT: 2,“IPV4V6”,“ims”,“0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0”,0,0,0,0
+CGDCONT: 3,“IPV4V6”,“sos”,“0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0”,0,0,0,1
In the above response, it is showing 3 context ID’s.
I have below queries:
1. Is there any specific use for every context ID?
2. How can I set the APN and PDPType on respective context ID’s?
3. Is there any way to decide to write APN and PDPType on which context ID?
Thank you…!!!
Regards,
Shabana Mulani.
