Hi I am using eg25-g on linux
I tried Quectel CM application to get the 4G connection I am able to ping IP address but not able to ping google.com(DNS not working I believe)
I Moved the script file to both folders as you suggested
here’s the log
sudo ./quectel-CM -s
[10-15_13:39:52:554] Quectel_QConnectManager_Linux_V1.6.0.12k
[10-15_13:39:52:555] Find /sys/bus/usb/devices/1-2.1 idVendor=0x2c7c idProduct=0x125, bus=0x001, dev=0x007
[10-15_13:39:52:556] Auto find qmichannel = /dev/cdc-wdm0
[10-15_13:39:52:556] Auto find usbnet_adapter = wwan0
[10-15_13:39:52:556] netcard driver = qmi_wwan_q, driver version = 22-Aug-2005
[10-15_13:39:52:556] ioctl(0x89f3, qmap_settings) failed: Operation not supported, rc=-1
[10-15_13:39:52:556] Modem works in QMI mode
[10-15_13:39:52:590] cdc_wdm_fd = 7
[10-15_13:39:53:591] QmiThreadSendQMITimeout pthread_cond_timeout_np timeout
[10-15_13:39:54:676] Get clientWDS = 17
[10-15_13:39:54:708] Get clientDMS = 1
[10-15_13:39:54:739] Get clientNAS = 3
[10-15_13:39:54:772] Get clientUIM = 2
[10-15_13:39:54:804] Get clientWDA = 1
[10-15_13:39:54:836] requestBaseBandVersion EG25GGBR07A07M2G
[10-15_13:39:54:963] requestGetSIMStatus SIMStatus: SIM_READY
[10-15_13:39:54:964] requestSetProfile[1] ///0
[10-15_13:39:55:027] requestGetProfile[1] ///0
[10-15_13:39:55:059] requestRegistrationState2 MCC: 525, MNC: 3, PS: Attached, DataCap: LTE
[10-15_13:39:55:092] requestQueryDataCall IPv4ConnectionStatus: DISCONNECTED
[10-15_13:39:55:093] ifconfig wwan0 down
[10-15_13:39:55:116] ifconfig wwan0 0.0.0.0
[10-15_13:39:55:188] requestSetupDataCall WdsConnectionIPv4Handle: 0x872a7930
[10-15_13:39:55:317] ifconfig wwan0 up
[10-15_13:39:55:340] busybox udhcpc -f -n -q -t 5 -i wwan0
udhcpc: started, v1.27.2
udhcpc: sending discover
udhcpc: sending select for 10.188.105.227
udhcpc: lease of 10.188.105.227 obtained, lease time 7200
[10-15_13:39:55:545] /etc/udhcpc/default.script: Resetting default routes
SIOCDELRT: No such process
[10-15_13:39:55:555] /etc/udhcpc/default.script: Adding DNS 8.8.8.8
[10-15_13:39:55:555] /etc/udhcpc/default.script: Adding DNS 8.8.4.4
I dont know what’s this error SIOCDELRT: No such process
Can you please help me asap ?
I have been working on this modem for quite a long
Thanks in advance
