Lenovo ThinkPad T14 Gen3 AMD
Ubuntu 22.04.02
no SIM card inserted - BUT same results with inserted SIM
T: Bus=01 Lev=01 Prnt=01 Port=03 Cnt=02 Dev#= 3 Spd=480 MxCh= 0
D: Ver= 2.00 Cls=ef(misc ) Sub=02 Prot=01 MxPS=64 #Cfgs= 1
P: Vendor=2c7c ProdID=030a Rev= 2.00
S: Manufacturer=Quectel
S: Product=Quectel EM05-G
C:* #Ifs= 3 Cfg#= 1 Atr=a0 MxPwr=500mA
A: FirstIf#= 0 IfCount= 2 Cls=02(comm.) Sub=0e Prot=00
I:* If#= 2 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=00 Prot=00 Driver=option
E: Ad=82(I) Atr=03(Int.) MxPS= 10 Ivl=32ms
E: Ad=81(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=01(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
I:* If#= 0 Alt= 0 #EPs= 1 Cls=02(comm.) Sub=0e Prot=00 Driver=cdc_mbim
E: Ad=84(I) Atr=03(Int.) MxPS= 64 Ivl=32ms
I: If#= 1 Alt= 0 #EPs= 0 Cls=0a(data ) Sub=00 Prot=02 Driver=cdc_mbim
I:* If#= 1 Alt= 1 #EPs= 2 Cls=0a(data ) Sub=00 Prot=02 Driver=cdc_mbim
E: Ad=83(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=02(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
mmcli -m 0 --verbose
[26 Apr 2023, 02:49:21] [Debug] ModemManager process found at ‘:1.11’
[26 Apr 2023, 02:49:21] [Debug] Assuming ‘0’ is the modem index
[26 Apr 2023, 02:49:21] [Debug] Modem found at ‘/org/freedesktop/ModemManager1/Modem/0’
[26 Apr 2023, 02:49:21] [Debug] Printing modem info…
General | path: /org/freedesktop/ModemManager1/Modem/0
| device id: f8ec3123425db7aa1071798b5f24e2cc76e0dc8b
Hardware | manufacturer: Quectel
| model: Quectel EM05-G
| firmware revision: EM05GFAR07A07M1G
| h/w revision: QUECTEL Mobile Broadband Modul
| supported: gsm-umts, lte
| current: gsm-umts, lte
| equipment id: 016176001891365
System | device: /sys/devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-4
| drivers: option, cdc_mbim
| plugin: quectel
| primary port: cdc-wdm0
| ports: cdc-wdm0 (mbim), ttyUSB0 (at), wwan0 (net)
Status | state: failed
| failed reason: sim-missing
| power state: low
Modes | supported: allowed: 3g, 4g; preferred: none
| current: allowed: 3g, 4g; preferred: none
IP | supported: ipv4, ipv6, ipv4v6
sudo screen /dev/ttyUSB0
AT+QGPSLOC=0
+QGPSLOC: 005113.0,5232.4380N,01314.2410E,3.6,38.5,2,141.15,0.0,0.0,260423,03
So GPS is running.
sudo gpsd -nNGD5 /dev/ttyUSB0
gpsd:INFO: launching (Version 3.22)
gpsd:IO: opening IPv4 socket
gpsd:IO: opening IPv6 socket
gpsd:INFO: listening on port gpsd
gpsd:PROG: NTP: shmat(360448,0,0) succeeded, segment 0
gpsd:PROG: NTP: shmat(360449,0,0) succeeded, segment 1
gpsd:PROG: NTP: shmat(360450,0,0) succeeded, segment 2
gpsd:PROG: NTP: shmat(360451,0,0) succeeded, segment 3
gpsd:PROG: NTP: shmat(360452,0,0) succeeded, segment 4
gpsd:PROG: NTP: shmat(360453,0,0) succeeded, segment 5
gpsd:PROG: NTP: shmat(360454,0,0) succeeded, segment 6
gpsd:PROG: NTP: shmat(360455,0,0) succeeded, segment 7
gpsd:PROG: successfully connected to the DBUS system bus
gpsd:PROG: shmget(0x47505344, 24512, 0666) for SHM export succeeded
gpsd:PROG: shmat() for SHM export succeeded, segment 360456
gpsd:INFO: stashing device /dev/ttyUSB0 at slot 0
gpsd:PROG: no /etc/gpsd/device-hook present, skipped running ACTIVATE hook
gpsd:INFO: SER: opening GPS data source type 3 at ‘/dev/ttyUSB0’
gpsd:INFO: SER: speed 9600, 8N1
gpsd:PROG: Probing “Garmin USB binary” driver…
gpsd:INFO: attempting USB device enumeration.
gpsd:INFO: 1d6b:0002 (bus 9, device 1)
gpsd:INFO: 1d6b:0003 (bus 10, device 1)
gpsd:INFO: 1d6b:0003 (bus 8, device 1)
gpsd:INFO: 1d6b:0002 (bus 7, device 1)
gpsd:INFO: 1d6b:0003 (bus 6, device 1)
gpsd:INFO: 30c9:0050 (bus 5, device 2)
gpsd:INFO: 1d6b:0002 (bus 5, device 1)
gpsd:INFO: 1d6b:0003 (bus 4, device 1)
gpsd:INFO: 06cb:00f9 (bus 3, device 2)
gpsd:INFO: 1d6b:0002 (bus 3, device 1)
gpsd:INFO: 1d6b:0003 (bus 2, device 1)
gpsd:INFO: 2c7c:030a (bus 1, device 3)
gpsd:INFO: 058f:9540 (bus 1, device 5)
gpsd:INFO: 10ab:9309 (bus 1, device 4)
gpsd:INFO: 05e3:0610 (bus 1, device 2)
gpsd:INFO: 1d6b:0002 (bus 1, device 1)
gpsd:INFO: vendor/product match with 091e:0003 not found
gpsd:PROG: Probe not found “Garmin USB binary” driver…
gpsd:PROG: Probing “GeoStar” driver…
gpsd:PROG: Sent GeoStar packet id 0xc1
gpsd:IO: SER: => GPS: 5053474700c100010000000050924746
gpsd:PROG: Probe not found “GeoStar” driver…
gpsd:PROG: Probing “Trimble TSIP” driver…
gpsd:INFO: SER: speed 9600, 8O1
gpsd:PROG: Probe not found “Trimble TSIP” driver…
gpsd:PROG: Probing “iSync” driver…
gpsd:IO: SER: => GPS: @@@@\x0d\x0aMAW0C0B\x0d\x0a
gpsd:PROG: Probe not found “iSync” driver…
gpsd:PROG: no probe matched…
gpsd:INFO: gpsd_activate(2): activated GPS (fd 6)
gpsd:PROG: NTP:PPS: using SHM(0)
gpsd:PROG: NTP:PPS: using SHM(1)
gpsd:PROG: PPS:/dev/ttyUSB0 chrony socket /run/chrony.ttyUSB0.sock doesn’t exist
gpsd:PROG: KPPS:/dev/ttyUSB0 checking /sys/devices/virtual/pps/pps0/path, /dev/ttyUSB0
gpsd:INFO: KPPS:/dev/ttyUSB0 RFC2783 path:/dev/pps0, fd is 7
gpsd:INFO: KPPS:/dev/ttyUSB0 pps_caps 0x1133
gpsd:INFO: KPPS:/dev/ttyUSB0 have PPS_CANWAIT
gpsd:INFO: KPPS:/dev/ttyUSB0 kernel PPS will be used
gpsd:PROG: PPS:/dev/ttyUSB0 thread launched
gpsd:INFO: PPS: activated /dev/ttyUSB0 ntpshm_link_activate(): Clock
gpsd:INFO: KPPS:/dev/ttyUSB0 kernel PPS timeout unknown error
gpsd:INFO: running with effective group ID 20
gpsd:INFO: running with effective user ID 124
gpsd:INFO: startup at 2023-04-26T00:56:58.000Z (1682470618)
gpsd:WARN: PPS:/dev/ttyUSB0 unchanged state, ppsmonitor sleeps 10
^Cgpsd:WARN: received terminating signal 2.
gpsd:INFO: closing GPS=/dev/ttyUSB0 (6)
gpsd:PROG: no /etc/gpsd/device-hook present, skipped running DEACTIVATE hook
gpsd:WARN: exiting.
gpsd:WARN: shmctl for IPC_RMID failed, errno = 1 (Operation not permitted)
sudo gpsmon
tcp://localhost:2947 JSON slave driver>
(82) {“class”:“VERSION”,“release”:“3.22”,“rev”:“3.22”,“proto_major”:3,“proto_minor”:14}
(172) {“class”:“DEVICES”,“devices”:[{“class”:“DEVICE”,“path”:“/dev/ttyUSB0”,“activated”:“2023-04-26T00:59:33.039Z”,“native”:0,“bps”:9600,“parity”:“N”,“stopbits”:1,“cycle”:1.00}]}
(122) {“class”:“WATCH”,“enable”:true,“json”:false,“nmea”:false,“raw”:2,“scaled”:false,“timing”:false,“split24”:false,“pps”:true}
Keeps empty.
What am I doing wrong here? Where is the modem sending the GPS data to?
Does it send GPS data anywhere?
I need help.
Thanks for taking the time to read and answer.
Best regards
Martin
