Network connection (PDCCH,PRACH) after PSM
I use BC95-G Modem with UEMonitor and i am trying to understand connection procedure to eNB after PSM mode..
I could read when modem go out psm mode and we will try to send data, the UE send PRACH frames (x3) and the eNB answering with PDCCH frame (contain TA, UL Grant and TC-RNTI(and i’m interested by these informations)
But when i read logs below of PSM mode + UDP frame i didn’t find any “PDCCH” with TA,UL Grant and RNTI information…
TEST2.Zip (246.7 KB)
Do you have an idea ? and how to obtain TA, UL Grant and RNTI informations ?
Thank’s for your help :slight_smile:
jojon
Please refer to the below screenshots
Thank you Herbet for crnti infromation.
I should find corresponding TA and UL Grant :slight_smile:
How to know if my modem is in PSM mode ?
I have try this command “AT+CPSMS=1,01000001,00100001”
And i have this response from debug
i dont know if my module is in PSM mode, how verify please ?
Please execute the command, if enter PSM, can output the corresponding URC
AT+NPSMR=1
Maybe, trace the log and execute the following Commands and make sure the URC output of the PSM. You upload the log and I will help you confirm from the signaling
AT+CFUN=0
AT+CFUN=1
AT+CGATT=1
Hello herbert,
thank for your help!
Below the log and traces of AT commands.
forherbert.Zip (250.6 KB)
AT+NPSMR=1
AT+NPSMR=1
AT+CFUN=0
AT+CFUN=0
+NPSMR:0
AT+CFUN=1
AT+CFUN=1
AT+CGATT=1
AT+CGATT=1
+NPSMR:1
Thanks :slight_smile:
You should check the network reply regarding your PSM values.
With at+cpsms the module will send the requested PSM values to the network.
If and which PSM values the network will grant you is reflected in at+cereg URC/output.
Enable URC with: at+cereg=4 or at+cereg=5
Then request at+cereg? output or wait for URC after setting at+cpsms value.
You’ll receive something like:
+CEREG: 4,5,C2F6,031B7B65,9,,,00000001,10101110
CEREG | Active time (T3324): 00000001 | TAU (T3412): 10101110
TAU: 1 minute x 14 = 14 minutes
T3324: 2 seconds x 1 = 2 seconds
Use e.g. calculation tool to decode the output.
