Need SDK for BC660K-GL
Please can you give me the download link for the latest version of the QuecOpen(OpenCpu) SDK for the BC660K-GL, also the latest firmware.
Thanks.
Hi Herbert
Could you please give me to the link for the latest version of QueckOpen SDK for BC66K-GL and the latest firmware? Thank you.
Does BC65 supports LwM2M protocol. if yes please share the application note.
Thanks,
Suhaib Saiyde.
Could you please send me the link to download the SDK as well, please?
Thanks.
Hi. I need the BC660K SDK please
Thanks for sending the SDK by email.
How can I have access to QFlash? Is it included on the SDK? if so, where is it?
Thanks in advance.
Qflash have be sent to your email,pls check
@herbert.pan-Q
When I try to build the sdk I am getting “make is not recognized as an internal or external command”.
How to solve this issue.
Thanks,
Suhaib Saiyde.
I have sent you the standard firmware version, and I suggest that you debug it by AT Commands under this version environment
Hi @herbert.pan-Q ,
I already have this firmware. we are trying to build an opencpu application with BC660SDK. Last time we were doing it with BC66. The folder arrangement for both the SDKs are different. When i try to compile the custom c code it is saying “Make is not recognized as an internal or external command”. We are not designing the device with AT commands. We need to build the open cpu version.
Thanks,
Suhaib Saiyde
Please provide relevant screenshots or logs
@herbert.pan-Q This is the error we got when we tried to build.
@herbert.pan-Q This is the folder structure of SDK
@herbert.pan-Q
We are not getting this pass message when we build the codes, neither warning nor error is printed.
Thanks,
Suhaib Saiyde
