Hello.
I have invested many hours trying to setup the RM530 module on Ubuntu 22.04 without any success.
lsusb show the Quectel module, and ls /dev/ttyUSB* list ttyUSB0..3
None of the usbnet options work (0,1,2,3).
I also tried DIP tools from this page from waveshare wiki portal - PCIe_TO_4G/5G_M.2_USB3.2_HAT%2B#Introduction - for usbnet modes 0 and 2. Didn’t work :(.
SIM card is recognized on slot 1 and register in the network using AT+CGDCONT=1,“IPV4V6”,“orangeworld”
I tried the same module on a fresh installed Raspberry Pi OS (64bits) and the module was recognized as usb0 and I just had to purge modemmanager and network-manager then get ip and dns to make it work. Unfortunately I cannot use RPi OS as this RPi is controlling a robot running ROS2 and only Ubuntu 22.04 is supported.
Thank you.
I see.
Could you show me that
lsusb -t
If you can send the AT command , could you show me the result of the AT
AT+QCFG="data_interface"
Hi, I am also trying RM530N-GL and PCIe TO 4G/5G M.2 USB3.2 HAT+. When I connect the 5G Hat to my windows laptop, my device manager cannot detect the modem even with the correct drivers installed. When I did lsusb inside the raspberry pi, it did not show the modem as well. However, I managed to detect the modem a few times. Is this a hardware or firmware issue?
If the rpi could detect the modem some time so the modem is in USB mode. And it should be something wrong with the hardware connection.
