Need EC20 firmware update
Got This error
FAIL, Ping_DLoad_Port_MDM9x07 timeout
Dear Sir,
Please make sure you use the right port USB DM port to upgrade the firmware. Thanks!
We have a pool of 16 module having usb serial connection, only showing 16 com ports.
Dear Sir,
Just as i have said that, please confirm whether you use the right COM port to upgrade the module firmware, you can just connect one module to have a try. Thanks!
I got some EC20CB-256-STD modules. When I try to active PDP context, it always return ERROR. Is there any firmware for this module?
Thanks.
Below is some message:
+CPIN: READY
+QUSIM: 1
+CREG: 2
+CGREG: 2
+CREG: 1
+CGREG: 1
+QIND: SMS DONE
+QIND: PB DONE
ATI
EC20
Revision: EC20CQAR02A04E2G_GW
AT+CREG?
+CREG: 1,1
AT+CGREG?
+CGREG: 1,1
AT+CEREG?
+CEREG: 0,4
AT+CEREG?
+CEREG: 0,4
AT+CEREG?
+CEREG: 0,4
AT+CEREG?
+CEREG: 0,4
AT+CEREG?
+CEREG: 0,4
AT+CEREG?
+CEREG: 0,4
AT+CEREG?
+CEREG: 0,4
AT+CEREG?
+CEREG: 0,1
AT+QIACT?
ERROR
AT+QIACT=1
ERROR
AT+QIACT?
ERROR
Dear Diag,
Please note that the module you used is quite old, it is better to change to our EC25 module.
For your issue, please use AT$MYNETACT command to active PDP, because it is GW module which used in China State Grid marketing, so it is better not use it in oversea marketing. Thanks!
Dear Kyson,
Thank you for your reply.
I know the EC20 module I owned is too old, and I found a flashed a firmware “EC20CQAR02A09E2G” luckly. I’m so glad this firmware version work. TCP trans/recv testing is OK.
It seems that everything work!
AT+QNTP?
AT+QNTP=?
+QNTP: (1-16),,(1-65535),(0,1)
AT+QNTP?
AT+CCLK?
+CCLK: “80/01/06,00:33:55”
AT+QNTP=1,“time.windows.com”,123
+QNTP: 0,“2020/03/11,11:15:39”
AT+CCLK?
+CCLK: “20/03/11,11:15:48”
AT+CCLK?
+CCLK: “20/03/11,11:15:53”
Thanks a lot! 非常感谢
Dear Kyson,
I use this module for testing, not for commercial applications.
Thanks.
Dear Sir,
We do not recommend you to flash the firmware EC20CQAR02A09E2G into the module with the software EC20CQAR02A04E2G_GW. If the firmware end with suffix GW, it is ok. If have no such suffix, it should not mixed each other. Thanks!
Dear Kyson,
This module is really old. Is there any firmware available for download with the suffix GW(Great Wall / Good Work / 国网 / LOL)? I’d like to flash back the original EC20CQAR02A04E2G_GW or other upgrade firmware suitable for the module. Thank you for you reply.
Dear kyson,
Is it possible to set at+ cmgf = 1 permanently? does not return to 0 when the module is restarted.
Dear Kyson,
I emailed the support and never got the firmware, just questions about my project, my provider etc.
Do I need to disclose all my personal info to receive the latest firmware of this buggy (in my case) modem??
If you do not provide firmware updates to users, could you please provide it to cz.nic as many of the turris omnia users with EC20 modem are experiencing major connection stability issues.
Dear Xpop,
If that, it is better to tell me your company name, your email address, and your country. I will share with your information with my colleague internal, and they will send your needed directly via email. Thanks!
Hi i got below results for ATI
EC20F
Revision: EC20CEFDKGR06A04M2G
can you please share latest firmware for this and specification for this module.
Dear Cloud,
Please click the following link to download the latest firmware of EC20CEFDGR06A07M2G. Thanks!
About specification, you can check the EC20 R2.1 spec. Please note that this module is used for domestic marketing in China, not for oversea marketing. Thanks!
Hi Kyson
Pls help me find latest firmware for UC15EQAR03A10E1G. Thanks !
Dear Linh,
Please create another new topic, your question is different from this topic here. And if you want the firmware, please email to support@quectel.com to get it. Thanks!
