Hi
I need a delta firmware image from BG770AGLAAR01A03 to BG770AGLAAR01A05_01.200.01.200 to test FOTA with the BG770A. Where can I find this?
Best regards
Hi
Best regards
Hello @wdLukas
Which firmware you are using now? could you please share the ATI response for us?
Ah sorry I used the wrong command.
Its: BG770AGLAAR01A03_01.002.01.002
I will apply it and share you soon.
Is there any update?
Hi @wdLukas
Internal verifying.
Hi @wdLukas
Please download with link:
Thank you very much. Worked like a charm!
As I tried to perform the FOTA update on multiple devices I realized I have at least one module with BG770AGLAAR01A03_01.007.01.007. Could you provide another delta image for BG770AGLAAR01A03_01.007.01.007 → BG770AGLAAR01A05_01.200.01.200.
Hi @wdLukas
Yes, sure. i will share you when finished
Hi @Linkin-Q
Could you provide the delta image?
Hi @wdLukas
Sorry for the late response, buiness trip those days.Please find below link to download DFOTA image.
Hi @Linkin-Q
Worked as expected. Thank you for your effort!
Hi @Linkin-Q
I tried to implement the DFOTA Update over serial for production and this was the first time I wanted to downgrade. The downgrade from BG770AGLAAR01A05_01.200.01.200 → BG770AGLAAR01A03_01.007.01.700 does not work. Sending it to the BG770AGL local storage is reported as ok. But as soon as I trigger the start I get CME Error 505. Any idea?
