Need Assistance with Quectel EC200U Module Internet Connectivity
I have a Quectel EC200U Module and aim to integrate it with my Orange Pi Zero 3 for internet access. My goal is to enable internet browsing on my Orange Pi, essentially using it as a standard laptop would. Despite consulting various guides and attempting different methods, I’ve encountered challenges in installing the necessary drivers.
While configuring and attempting to compile the files using menuconfig, I’m encountering errors such as “scripts/sortextable.c:31:10: fatal error: tools/be_byteshift.h: No such file or directory**” and “fatal error: classmap.h: No such file or directory**.”
Could someone please provide guidance on the appropriate documentation and driver support required for establishing internet connectivity on my Orange Pi? I’ve been following a guide available at “https://sixfab.com/wp-content/uploads/2022/05/Quectel_UMTS_LTE_5G_Linux_USB_Driver_User_Guide_V3.0.pdf.
I am using the Ubuntu 20.04 as my OS downloaded from the OrangePi Website and the Kernel version is 5.4.0-125.
I appreciate any assistance provided in advance.
Thank you.
See if you can use a newer kernel. EC200U got support in option driver around v5.15.90
Before that you will need to manually add the vid:pid to the driver using newid mechanism. No compilation is necessary.
Your data interface should be already picked by the standard cdc_ether driver, check with cat /sys/kernel/debug/usb/devices
Okay. I will try with a kernel version higher than 5.15.90.
I installed the Orange Pi OS for Ubuntu version 22.04 and it works. Now I am able to connect to it via Serial Interface. I am able to run all the AT Commands. But I want to use it as modem for my OrangePi, how can I do that. I have tried using Modem Manager but it showing Segmentation Fault and I have tried to add it as Mobile Broadband connection from the network settings but that too is not working. What are the other option I can try to use it as modem?
You don’t need ModemManager, remove it.
Show the output of cat /sys/kernel/debug/usb/devices
T: Bus=01 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#= 1 Spd=480 MxCh= 1
B: Alloc= 0/800 us ( 0%), #Int= 1, #Iso= 0
D: Ver= 2.00 Cls=09(hub ) Sub=00 Prot=00 MxPS=64 #Cfgs= 1
P: Vendor=1d6b ProdID=0002 Rev= 6.01
S: Manufacturer=Linux 6.1.31-sun50iw9 ehci_hcd
S: Product=EHCI Host Controller
S: SerialNumber=5200000.usb
C:* #Ifs= 1 Cfg#= 1 Atr=e0 MxPwr= 0mA
I:* If#= 0 Alt= 0 #EPs= 1 Cls=09(hub ) Sub=00 Prot=00 Driver=hub
E: Ad=81(I) Atr=03(Int.) MxPS= 4 Ivl=256ms
T: Bus=01 Lev=01 Prnt=01 Port=00 Cnt=01 Dev#= 3 Spd=480 MxCh= 0
D: Ver= 2.00 Cls=00(>ifc ) Sub=00 Prot=00 MxPS=64 #Cfgs= 1
P: Vendor=2c7c ProdID=0901 Rev= 3.18
S: Manufacturer=Android
S: Product=Android
C:* #Ifs= 9 Cfg#= 1 Atr=e0 MxPwr=400mA
A: FirstIf#= 0 IfCount= 2 Cls=e0(wlcon) Sub=01 Prot=03
I:* If#= 0 Alt= 0 #EPs= 1 Cls=e0(wlcon) Sub=01 Prot=03 Driver=rndis_host
E: Ad=82(I) Atr=03(Int.) MxPS= 8 Ivl=4096ms
I:* If#= 1 Alt= 0 #EPs= 2 Cls=0a(data ) Sub=00 Prot=00 Driver=rndis_host
E: Ad=81(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=01(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
I:* If#= 2 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=00 Prot=00 Driver=option
E: Ad=84(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=02(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=83(I) Atr=03(Int.) MxPS= 512 Ivl=4096ms
I:* If#= 3 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=00 Prot=00 Driver=option
E: Ad=85(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=03(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
I:* If#= 4 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=00 Prot=00 Driver=option
E: Ad=86(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=04(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
I:* If#= 5 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=00 Prot=00 Driver=option
E: Ad=87(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=05(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
I:* If#= 6 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=00 Prot=00 Driver=option
E: Ad=88(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=06(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
I:* If#= 7 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=00 Prot=00 Driver=option
E: Ad=8a(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=07(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=89(I) Atr=03(Int.) MxPS= 512 Ivl=4096ms
I:* If#= 8 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=00 Prot=00 Driver=option
E: Ad=8b(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=08(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
T: Bus=02 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#= 1 Spd=480 MxCh= 1
B: Alloc= 0/800 us ( 0%), #Int= 0, #Iso= 0
S: SerialNumber=5310000.usb
T: Bus=03 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#= 1 Spd=480 MxCh= 1
S: SerialNumber=5311000.usb
T: Bus=04 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#= 1 Spd=12 MxCh= 1
B: Alloc= 0/900 us ( 0%), #Int= 0, #Iso= 0
D: Ver= 1.10 Cls=09(hub ) Sub=00 Prot=00 MxPS=64 #Cfgs= 1
P: Vendor=1d6b ProdID=0001 Rev= 6.01
S: Manufacturer=Linux 6.1.31-sun50iw9 ohci_hcd
S: Product=Generic Platform OHCI controller
S: SerialNumber=5200400.usb
E: Ad=81(I) Atr=03(Int.) MxPS= 2 Ivl=255ms
T: Bus=05 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#= 1 Spd=12 MxCh= 1
S: SerialNumber=5310400.usb
T: Bus=06 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#= 1 Spd=12 MxCh= 1
S: SerialNumber=5311400.usb
Switch from RNDIS to ECM with AT+QCFG="usbnet",1
Configure the APN with at+qicsgp=1,1,"your apn"
Check the context activation status with AT+QIACT?
“Dial” with at+qnetdevctl=1,1,1
Then run DHCP client on the interface associated with the modem, it should be mentioned in dmesg next to cdc_ether.
It works. Thank you! :v:
Do you have any documentation where I can read more regarding this?
Hi jfrog , i am trying to setup modem for raspberry pi. but there is no internet i am getting. able to send SMS
Here os the output of sudo cat /sys/kernel/debug/usb/devices of myh raspbeery pi. but internet is not working
 Bus=01 Lev=02 Prnt=02 Port=02 Cnt=02 Dev#= 16 Spd=480  MxCh= 0
S:  Product=Android
A:  FirstIf#= 0 IfCount= 2 Cls=02(comm.) Sub=06 Prot=00
I:* If#= 0 Alt= 0 #EPs= 1 Cls=02(comm.) Sub=06 Prot=00 Driver=cdc_ether
E:  Ad=81(I) Atr=03(Int.) MxPS=  16 Ivl=32ms
I:  If#= 1 Alt= 0 #EPs= 0 Cls=0a(data ) Sub=00 Prot=00 Driver=cdc_ether
I:* If#= 1 Alt= 1 #EPs= 2 Cls=0a(data ) Sub=00 Prot=00 Driver=cdc_ether
E:  Ad=82(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
these are the interfaces i have but usb0 is shown down.
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
    inet 127.0.0.1/8 scope host lo
       valid_lft forever preferred_lft forever
2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
    link/ether b8:27:eb:70:e3:7b brd ff:ff:ff:ff:ff:ff
    inet 10.1.2.197/22 brd 10.1.3.255 scope global dynamic noprefixroute eth0
       valid_lft 42005sec preferred_lft 42005sec
    inet6 fe80::c783:368c:6227:4d73/64 scope link noprefixroute
3: wlan0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc pfifo_fast state DOWN group default qlen 1000
    link/ether 3e:bd:71:53:d2:2d brd ff:ff:ff:ff:ff:ff permaddr b8:27:eb:25:b6:2e
9: usb0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc pfifo_fast state DOWN group default qlen 1000
    link/ether 02:4b:b3:b9:eb:e5 brd ff:ff:ff:ff:ff:ff
i am using Jio sim . Below is the commands i used to setup
python3 setnet.py
Sent: AT
Received:
Sent: AT+CREG?
Received:
+CREG: 0,1
Sent:  AT+QCFG="usbnet",1
Received:
setting APN
Sent: at+qicsgp=1,2,"JioNet"
Received:
ERROR
check ip address
Sent: at+qiact=1
Received:
ERROR
Sent: AT+CGPADDR=1
Received:
+CGPADDR: 1,"2409:4050:2D8C:317D::AE8A:2813"
Sent: AT+CMGF=1
Received:
Sent: AT+CMGS="+919313141232"
Received:
SMS send response:
+CMGS: 70
SMS sent successfully!
Jio is IPv6 only. Your modem already obtained an address from the carrier, so you need to configure the host to obtain the address from the modem. Once you get IPv6 connectivity you will need to figure out what you can do with IPv4.
It is probably already activated, worth checking the current state first as suggested earlier.
Probably because the context is in active state. I would deactivate it first or even get the modem offline with at+cfun=4 and try again.
how to do it ? could you please help .
Unrelated to Quectel. Please refer to networking guide for your Linux distribution.
