Hii, Everyone
I have a BG77 GSM module and JIO NB-IOT Sim card (INDIA), I connect sim with module to activate NB-IOT functionality.
But i received every time +CREG: 0,2 response, at once i received +CREG: 0,1 response but after some time continuously i received same response as before 0,2
I can’t get exactly what is the problem is there.
Is anyone can have solution or suggestion for that?
Please it grateful for me
Roaming service or not?
and we suggest to use AT+CEREG? to check NB/CATM network status.
Hi @Linkin-Q
I tried At+CEREG? command as you say, but still i received 0,2 response and some times 0,0 also
and yes the JIO sim which i have is support roaming service, i think you ask for it right?
Hi @Akshit279
please try with command: AT+QNWCFG=“hplmnsearch_ctrl”,0 to disable HPLMN search when in roaming service, reboot to take effect.
Hi @Linkin-Q
I tried command (AT+QNWCFG=“hplmnsearch_ctrl”,0) as you say ,but still not work for me.
Still I get response 0,0
OK so we need check modem log, do you have skype then we can discuss there for more detail informations.
@ Akshit, Did you tried to set reduced bands instead of checking all bands via AT command? If not then please give a try this
Band 3 (1800 MHz), Band 5 (850 MHz) and Band 8 (900 MHz)
Hi Akshit,
I am trying to get Jio NB-Iot SIM card for a use-case I am working on. How did you get it and can you help me get a Jio NB-IoT SIM card?
