Multi-carrier SIM for EC25-AF?
Any recommendation for multi-carrier SIM in the USA, to use either ATT&T or Verizon ?
Could you provide a little detail on your use case?
I’m biased since I’m a contractor for KORE Wireless. KORE has several different multi-carrier, and multi-imsi offerings as well as imsi steering features on their sims. KORE has their inhouse developed product called OmniSIM which does what you are looking for, and KORE acquired Twilio’s IOT department this year and with it their SuperSim which does what you are looking for also. The two have some slight differences. You can see some details on the offerings below.
@sstenzel Did you get any feedback on this topic? I’m using EG25-G internal modem for RUT241 global from Teltonika and I’m struggling with this SIM cards. Any idea? The behaviour I’m seeing is the modem will work for a while before it will drop the communication and never recover. Only reset the modem helps so far.
