when we send one attach reqest to network , it include one MTU request ,by default , MTU=1500 , when the net work reply this request . it will send one network value approved by network , as you said , maybe it is 1430 , the device will change to 1430 , if not , the device will use the default value (1500)
Stephen, thank you for the reply.
However it does not answer my question - how would a host CPU discover the MTU assigned by the network ?
If the host CPU is using ATD and PPP and running its own TCP/IP stack (and not using the sockets AT commands) there does not seem to be a way for the TCP/IP stack on the host CPU to discover if the MTU is reduced below 1500.
I would expect the modem PPP LCP sublayer to include a MRU option but I don’t see an MRU option from either BG95M1 or EG91NAXD.
