Hello, I adapt EC20 r2.0 module on mtk9632 platform, Android version is 9.0, kernel version is 4.9.
In fact, EC20 is written on the module. I use lsusb to check vid:pid It is: 2c7c: 0125, so it should be EC20 r2.0; now, I want to realize PPP dial-up Internet access,My operation steps are as follows:
1.I configured according to 3.2 and 3.6 of the document:《Quectel_WCDMA<E_Linux_USB_Driver_User_Guide_V1.8.pdf》, and copied files in “linux-ppp-scripts_V1.2.zip” to the directory of the development board: /etc /PPP/peers
2.then, create the directories:/var/lock and /var/run
3.Check the network status with at command:
4.Then I use “pppd call quertel -ppp” to test PPP dial-up Internet access, and the print is as follows:
pppd call quectel-ppp
pppd options in effect:
debug # (from /etc/ppp/peers/quectel-ppp)
nodetach # (from /etc/ppp/peers/quectel-ppp)
dump # (from /etc/ppp/peers/quectel-ppp)
noauth # (from /etc/ppp/peers/quectel-ppp)
user test # (from /etc/ppp/peers/quectel-ppp)
password ??? # (from /etc/ppp/peers/quectel-ppp)
remotename 3gppp # (from /etc/ppp/peers/quectel-ppp)
/dev/ttyUSB3 # (from /etc/ppp/peers/quectel-ppp)
115200 # (from /etc/ppp/peers/quectel-ppp)
lock # (from /etc/ppp/peers/quectel-ppp)
connect chat -s -v -f /etc/ppp/peers/quectel-chat-connect # (from /etc/ppp/peers/quectel-ppp)
disconnect chat -s -v -f /etc/ppp/peers/quectel-chat-disconnect # (from /etc/ppp/peers/quectel-ppp)
nocrtscts # (from /etc/ppp/peers/quectel-ppp)
modem # (from /etc/ppp/peers/quectel-ppp)
hide-password # (from /etc/ppp/peers/quectel-ppp)
novj # (from /etc/ppp/peers/quectel-ppp)
novjccomp # (from /etc/ppp/peers/quectel-ppp)
ipcp-accept-local # (from /etc/ppp/peers/quectel-ppp)
ipcp-accept-remote # (from /etc/ppp/peers/quectel-ppp)
ipparam 3gppp # (from /etc/ppp/peers/quectel-ppp)
noipdefault # (from /etc/ppp/peers/quectel-ppp)
ipcp-max-failure 30 # (from /etc/ppp/peers/quectel-ppp)
defaultroute # (from /etc/ppp/peers/quectel-ppp)
usepeerdns # (from /etc/ppp/peers/quectel-ppp)
noccp # (from /etc/ppp/peers/quectel-ppp)
abort on (BUSY)
abort on (NO CARRIER)
abort on (NO DIALTONE)
abort on (ERROR)
abort on (NO ANSWER)
timeout set to 30 seconds
send (AT^M)
expect (OK)
^DSCI: 2,0,2,1,abA,129
+CREG: 2
alarm
Failed
Script chat -s -v -f /etc/ppp/peers/quectel-chat-connect finished (pid 5282), status = 0x3
Connect script failed
^DSCI: 2,0,6,1,abA,129
ATE0Q0V1
What should I do? In order to achieve the purpose of PPP dial-up Internet access
