Hi, if and when will BC92 be able to support MQTT over TLS. AWS IoT core requires MQTT/TLS to utilise their services fully.
Hi Heinrich
BC92 currently has no plans to support TLS functionality.
Hi Abner, how would you then recommend to use AWS IoT Core with the BC92
Here are the full commands to use SSL in the BC92 module.
AT+QSSLCFG=1,5,"seclevel",2
AT+QSSLCFG=1,5,"cacert"
"insert the CA cert"
CTRL-Z
+QSSLCFG: 1,5,"cacert",1452
AT+QSSLCFG=1,5,"clientcert"
"insert the client certificate"
CTRL-Z
+QSSLCFG: 1,5,"clientcert",1298
AT+QSSLCFG=1,5,"clientkey"
"insert the client key"
CTRL-Z
+QSSLCFG: 1,5,"clientkey",1704
AT+QMTCFG="version",3,1
+CSCON: 0
AT+QMTCFG="ssl",3,1,1,5
AT+QMTOPEN=3,"test.mosquitto.org",8884
+CSCON: 1
+QMTOPEN: 3,0
AT+QMTCONN=3,"nouvennbc92"
+QMTCONN: 3,0,0
AT+QMTSUB=3,1,"nouvenn/",1
+QMTSUB: 3,1,0,1
AT+QMTPUB=3,0,0,0,"nouvenn/"
TesteNouvenn
CTRL-Z
+QMTPUB: 3,0,0
+QMTRECV: 3,0,nouvenn/,TesteNouvenn
