Hi! I’m developing MQTT client by using BG95 module.
When I try connect MQTT broker, +QMTOPEN:0,-1 error occurs.
I send AT command by using Python and this script works well on AWS IoT.
I already serach +QMTOPEN related Topic in this forum and check downloaded certification filse and sizes are exactly same with original files. The MQTT server working well on MQTTX program with same certifications (CA or Self signed certificates). Thanks!
ATE0
<< OK
AT+CFUN=1
<< OK
AT+CREG?
<< +CREG: 0,0
<< OK
AT+CEREG?
<< +CEREG: 0,5
<< OK
AT+CGDCONT=1,“IP”,“iot.1nce.net”
<< OK
AT+CGATT=1
<< OK
AT+QNWINFO
<< +QNWINFO: “eMTC”,“45006”,“LTE BAND 5”,2600
<< OK
AT+QIACT=1
<< ERROR
AT+QIACT?
<< +QIACT: 1,1,1,“10.248.112.85”
<< OK
Sending ‘ca.crt’ to BG95 as ‘UFS:ca.crt’ (1184 bytes)
AT+QFDEL=“UFS:ca.crt”
<< OK
AT+QFUPL=“UFS:ca.crt”,1184,5000
<< CONNECT
<< +QFUPL: 1184,300
<< OK
Sent file ca.crt to BG95 successfully.
Sending ‘client.crt’ to BG95 as ‘UFS:client.crt’ (1162 bytes)
AT+QFDEL=“UFS:client.crt”
<< OK
AT+QFUPL=“UFS:client.crt”,1162,5000
<< CONNECT
<< +QFUPL: 1162,177f
<< OK
Sent file client.crt to BG95 successfully.
Sending ‘client.key’ to BG95 as ‘UFS:client.key’ (1732 bytes)
AT+QFDEL=“UFS:client.key”
<< OK
AT+QFUPL=“UFS:client.key”,1732,5000
<< CONNECT
<< +QFUPL: 1732,7659
<< OK
Sent file client.key to BG95 successfully.
AT+QMTCFG=“ssl”,0,1,2
<< OK
AT+QMTCFG=“version”,0,4
<< OK
AT+QSSLCFG=“cacert”,2,“UFS:ca.crt”
<< OK
AT+QSSLCFG=“clientcert”,2,“UFS:client.crt”
<< OK
AT+QSSLCFG=“clientkey”,2,“UFS:client.key”
<< OK
AT+QSSLCFG=“seclevel”,2,2
<< OK
AT+QSSLCFG=“sslversion”,2,4
<< OK
AT+QMTOPEN=0,“my mqtt address”,8883
<< OK
<< +QMTOPEN: 0,-1
Thanks for your advice.
I apply sni with 2,0 or 2,1, the result is always same. I will adjust another SSL related parameters.
<< OK
AT+QMTCFG=“version”,0,3
<< OK
<< OK
<< OK
<< OK
<< OK
AT+QSSLCFG=“sslversion”,2,3
<< OK
AT+QSSLCFG=“sni”,2,1
<< OK
AT+QSSLCFG=“checkhost”,2,1
<< OK
AT+QMTOPEN=0,“my mqtt address”,7008
<< OK
<< +QMTOPEN: 0,-1
AT+QMTCONN=0,“000003”
<< ERROR
MQTT Connection Failed
MQTT Connection or publish failed
I have tested new firmware but test result was same. +QMTOPEN : 0, -1 error is same.
When I connect to AWS MQTT, it works well. But I try to connect Synology MQTT, it did not work.
If I did not use SSL, it was well connected to Synology. So, I think that there are some problem on CA certification compatibility.
Any way, thanks for your help and wish you have happy new year!
I am trying to send data from Quectel EC200U-CN to the AWS server using MQTT AT commands.
But the AT+QMTOPEN command always gives a response as +QMTOPEN: 1,5 or +QMTOPEN: 1,1
And this is my command sequence
AT+COPS?
AT+CREG=2
AT+CREG?
AT+CREG=0
AT+QIDEACT=1
AT+CGDCONT=1,“IP”,“xxxxxxxxx”
AT+QIACT=1
AT+QFLST=“*”
AT+QSSLCFG=“sslversion”,1,4
AT+QSSLCFG=“ciphersuite”,1,0xFFFF
AT+QSSLCFG=“seclevel”,1,2
AT+QSSLCFG=“cacert”,1,“UFS:cacert.pem”
AT+QSSLCFG=“clientcert”,1,“UFS:client.pem”
AT+QSSLCFG=“clientkey”,1,“UFS:client_key.pem”
AT+QSSLCFG=“ignorelocaltime”,1,1
AT+QMTCFG=“version”,1,4
AT+QMTCFG=“ssl”,1,1,1
AT+QMTCFG=“pdpcid”,1,
AT+QMTOPEN=1,“82.112.238.2”,8883
