Hi, I’ve been dealing with this for a month. Can you help me? I think I’ve done all the settings. The test patten works fine, but the screen doesn’t work normally. I don’t know how much my dsi clock frequency is, how can I find out. Can you help me?
DSİ TOOL OUTPUT
%CHIP1%PVCA%PMCA%RPCA1280%RLCA800%PVCB%PMCB%RPCB%RLCB%LVCM0%HPWA54%HBPA54%HFPA52%HACA1280%HTOA1440%HPWB%HBPB%HFPB%HACB%HTOB0%VPWA8%VBPA8%VFPA7%VACA800%VTOA823%VPWB%VBPB%VFPB%VACB%VTOB0%PCKN71.1%LCKS1%RCKM24%MULT2%DCKA%DIVI0%LCKR72.0%FMTA1%DEPA0%HSPA1%VSPA1%BPPA1%FMTB1%DEPB0%HSPB1%VSPB1%BPPB0%PRDA1280x800%PRDBx%DSCM0%LREO1%LRCE1%LPCA0%BMCA0%SMCA0%LPCB0%BMCB0%SMCB0%DHPA54%DHBA54%DHFA52%DHAA1280%DHTA1440%DHPB%DHBB%DHFB%DHAB%DHTB%DVPA8%DVBA8%DVFA7%DVAA800%DVTA823%DVPB%DVBB%DVFB%DVAB%DVTB%DDRA213.3%NOLA3%VIMA2%LCRP%DDRB%NOLB0%VIMB0%RCRP
MY DİSPLAY PDF
PV10107LZR40E.pdf (1.4 MB)
DMESG OUTPUT
[ 4.360701] mipi_convert 1-002c: backlight_en gpio not provided
[ 4.360728] mipi_convert 1-002c: irq gpio not provided
[ 4.365483] mipi_convert 1-002c: 1-002c supply avdd not found, using dummy regulator
[ 4.370660] mipi_convert 1-002c: convert IC probe success
[ 4.378557] mipi_convert 1-002c: init convert IC ...
[ 6.331045] mipi_convert 1-002c: reg: 9, READ8: 0
[ 6.350986] mipi_convert 1-002c: reg: a, READ8: 84
[ 6.370981] mipi_convert 1-002c: reg: b, READ8: 2
[ 6.390981] mipi_convert 1-002c: reg: d, READ8: 1
[ 6.410981] mipi_convert 1-002c: reg: 10, READ8: 26
[ 6.430981] mipi_convert 1-002c: reg: 11, READ8: 0
[ 6.450981] mipi_convert 1-002c: reg: 12, READ8: 2a
[ 6.470981] mipi_convert 1-002c: reg: 13, READ8: 0
[ 6.490981] mipi_convert 1-002c: reg: 18, READ8: 78
[ 6.510981] mipi_convert 1-002c: reg: 19, READ8: 0
[ 6.530981] mipi_convert 1-002c: reg: 1a, READ8: 3
[ 6.550981] mipi_convert 1-002c: reg: 1b, READ8: 0
[ 6.570981] mipi_convert 1-002c: reg: 20, READ8: 0
[ 6.590981] mipi_convert 1-002c: reg: 21, READ8: 5
[ 6.610981] mipi_convert 1-002c: reg: 22, READ8: 0
[ 6.630981] mipi_convert 1-002c: reg: 23, READ8: 0
[ 6.650981] mipi_convert 1-002c: reg: 24, READ8: 0
[ 6.670981] mipi_convert 1-002c: reg: 25, READ8: 0
[ 6.690981] mipi_convert 1-002c: reg: 26, READ8: 0
[ 6.710981] mipi_convert 1-002c: reg: 27, READ8: 0
[ 6.730981] mipi_convert 1-002c: reg: 28, READ8: 20
[ 6.750981] mipi_convert 1-002c: reg: 29, READ8: 0
[ 6.770981] mipi_convert 1-002c: reg: 2a, READ8: 0
[ 6.790982] mipi_convert 1-002c: reg: 2b, READ8: 0
[ 6.810982] mipi_convert 1-002c: reg: 2c, READ8: 36
[ 6.830981] mipi_convert 1-002c: reg: 2d, READ8: 0
[ 6.850981] mipi_convert 1-002c: reg: 2e, READ8: 0
[ 6.870981] mipi_convert 1-002c: reg: 2f, READ8: 0
[ 6.890981] mipi_convert 1-002c: reg: 30, READ8: 8
[ 6.910981] mipi_convert 1-002c: reg: 31, READ8: 0
[ 6.930982] mipi_convert 1-002c: reg: 32, READ8: 0
[ 6.950981] mipi_convert 1-002c: reg: 33, READ8: 0
[ 6.970981] mipi_convert 1-002c: reg: 34, READ8: 36
[ 6.990980] mipi_convert 1-002c: reg: 35, READ8: 0
[ 7.010981] mipi_convert 1-002c: reg: 36, READ8: 0
[ 7.030981] mipi_convert 1-002c: reg: 37, READ8: 0
[ 7.050981] mipi_convert 1-002c: reg: 38, READ8: 0
[ 7.070981] mipi_convert 1-002c: reg: 39, READ8: 0
[ 7.090981] mipi_convert 1-002c: reg: 3a, READ8: 0
[ 7.110981] mipi_convert 1-002c: reg: 3b, READ8: 0
[ 7.130981] mipi_convert 1-002c: reg: 3c, READ8: 0
[ 7.150981] mipi_convert 1-002c: reg: 3d, READ8: 0
[ 7.170981] mipi_convert 1-002c: reg: 3e, READ8: 0
[ 7.190981] mipi_convert 1-002c: reg: d, READ8: 1
[ 7.210981] mipi_convert 1-002c: reg: 9, READ8: 0
[ 7.212701] qcom-sps-dma c144000.qcom,sps-dma: dma_async_device_register: device has no channels!
[ 7.212784] qcom-sps-dma c184000.qcom,sps-dma: dma_async_device_register: device has no channels!
[ 7.222377] iommu: Adding device 18800000.qcom,icnss to group 4
[ 7.229459] icnss: Recursive recovery allowed for WLAN
[ 7.235945] icnss 18800000.qcom,icnss: for wcss_msa0 segments only will be dumped.
[ 7.240459] icnss: Platform driver probed successfully
[ 7.252715] memshare_child soc:qcom,memshare:qcom,client_1: for memshare_GPS segments only will be dumped.
[ 7.253096] memshare_child soc:qcom,memshare:qcom,client_2: for memshare_FTM segments only will be dumped.
[ 7.262725] memshare_child soc:qcom,memshare:qcom,client_3: for memshare_DIAG segments only will be dumped.
[ 7.272966] pil-q6v5-mss 4080000.qcom,mss: No pas_id found.
[ 7.282048] platform 4080000.qcom,mss:qcom,mba-mem@0: assigned reserved memory node pil_mba_region@94800000
[ 7.288510] minidump-id not found for venus
how should i progress
