Mini PCIe Uart Pin Mapping
Hello
I want to add a mini pcie adapter to a sensor box.
I want to be able to use different kind of queltec modem,
is the pin-mapping for uart the same on all mini pcie cards ?
I have checked all Hardware design documents i could find (~12)
they all had the same pin mapping for uart. Is this consitent ?
Kind regards,
Nils
hello, could you tell us your current module type or FW version? thanks~
This question was about all Modems that are sold as a mini PCIe-Card.
As far as i can tell they all use the same pins for UART.
Is this assumption correct ?
Kind regards,
Nils
@mikey hi mikey, could you please help to support this issue? thanks~
Hi
Yes, Mini PCles have the same UART pin position.
Hey,
thanks for the reply, i can continue in good conscience then :slight_smile:
