Mikrotik ATL LTE18 kit (ATLGM&EG18-EA)
Hello, Quectel Support! I am using a MikroTik ATLGMEG18-EA kit with the EG18-EA modem. After updating the firmware to version EG18EAPAR01A13M4G_01.300.01.300, I encountered a regional lock and can no longer register on local networks. Since a direct downgrade to older versions via RouterOS is blocked, could you please provide a stable alternative firmware with the _01.300 bootloader (for example, EG18EAPAR01A13M4G_01.201.01.201)? Thank you in advance.
I have sent the EG18EAPAR01A13M4G_01.201.01.201 to your email, pls check and try again
What are the instructions for the Mikrotik ATL LTE18 kit (ATLGM&EG18-EA) downgrade?
I have the same problem, could you please send me a copy of firmware
Best regards,
Sergey
sergey@bondarenko.tech
