HELLO
I am using the MC60CA and MC60ECA modules. In module MC60E, the ‘Ql_GNSS_PowerOn’ function does not work and returns the answer -10000, which is equivalent to the error of Ql_RET_NOT_SUPPORT.
While this function works correctly in the MC60 module.
Is there any solution for me?
more details:
Revision is: MC60ECAR01A01
The code of both the programs of MC60CA and MC60ECA modules is similar.
The description of the Ql_GNSS_PowerOn function is as follows:
* Function: Ql_GNSS_PowerOn
* Description:
* This function is used to power on the GNSS and register the callback function for the
* specified NMEA sentences.
* NMEA callback function used for receiving the NMEA sentences from CORE by parameters
* of nmea_buff and len.
* NOTE:
* The stack size of task calling this function shouldn't less than 2kB.
* This function should be called in pairs with Ql_GNSS_PowerDown.
* Parameters:
* [in]nmea_type:
* NMEA types be enabled to output which can multiselect by OR the bit mask.
* For example, RMC_EN | GGA_EN will enable RMC and GGA sentences to output.
* [in]callback_nmea:
* The pointer of the NMEA call back function.
* [in]customizePara:
* Customize parameter, if not use just set to NULL.
* Return:
* QL_RET_OK indicates success;
* Ql_RET_ERR_MEM_FULL indicates malloc memory failed.
* QL_RET_ERR_GNSS_OPERATION_FAILED indicates operation failure when power on or power down.
