I have been using the MC60 module for my IoT project. I wanted to know what is memory space available for storing data via File AT commands in module UFS.
Note: I’m already using around 4-5kb on flash memory to store SSL certificates.
Thanks.
Dear Altamash,
Thanks for your inquiry in Quectel forums.
If you want to check the UFS size of the module, you can use the command AT+QFLDS to check it. Thanks!
Yeah I just saw it in the application note. Thanks.
