MC60 SSL with root cert file
hello
i am getting some error while implimening SSL
ESP-ROM:esp32c3-api1-20210207
Build:Feb 7 2021
rst:0x1 (POWERON),boot:0xc (SPI_FAST_FLASH_BOOT)
SPIWP:0xee
mode:DIO, clock div:1
load:0x3fcd5810,len:0x438
load:0x403cc710,len:0x90c
load:0x403ce710,len:0x2624
entry 0x403cc710
=== MC60 MQTT SSL FIX START ===
AT
ATE0
AT+CFUN=1
AT+CPIN?
+CPIN: READY
AT+CREG?
+CREG: 0,5
AT+CGATT=1
AT+QIDEACT
DEACT OK
AT+QIREGAPP=“VILESIM”,“”,“”
AT+QIACT
AT+QILOCIP
10.67.253.43
AT+QMTCFG=“keepalive”,0,60
AT+QSSLCFG=“cacert”,2,“”
ERROR
AT+QSECDEL=“UFS:cacert.pem”
Calculated Certificate Length: 1940
AT+QSECWRITE=“UFS:cacert.pem”,1940,100
CONNECT
+QSECWRITE: 1940,6e4f
AT+QSSLCFG=“cacert”,2,“UFS:cacert.pem”
AT+QSSLCFG=“seclevel”,2,1
AT+QSSLCFG=“sslversion”,2,4
AT+QSSLCFG=“ciphersuite”,2,“0xFFFF”
AT+QSSLCFG=“ignorertctime”,1
AT+QMTCFG=“SSL”,0,1,2
AT+QMTOPEN=0,“mqtt-lets.balwaan.com”,8883
+QMTOPEN: 0,-1
MQTT SSL CONNECT FAILED
SSL code -
Phase 1: Network & GPRS Attachment
Before doing anything with SSL, the modem must be “online” and have a valid IP address.
  1. AT → Verifies modem communication.
  2. ATE0 → Disables command echoing to keep responses clean.
  3. AT+CFUN=1 → Sets the modem to full functionality.
  4. AT+CPIN? → Checks if the SIM card is ready.
  5. AT+CREG? → Checks if the modem is registered on the cellular network.
  6. AT+CGATT=1 → Attaches to the GPRS service.
  7. AT+QIDEACT → Deactivates the previous PDP context (clean slate).
  8. AT+QIREGAPP="VILESIM","","" → Sets the APN for your provider.
  9. AT+QIACT → Activates the GPRS context.
  10. AT+QILOCIP → Requests the local IP address (confirms connection).
Phase 2: Certificate Management (SSL Storage)
This phase uploads the ISRG Root X1 certificate to the modem’s internal flash memory (UFS).
  1. AT+QSSLCFG="cacert",2,"" → Clears any existing CA cert assigned to SSL context 2.
  2. AT+QSECDEL="UFS:cacert.pem" → Deletes any old certificate file from memory.
  3. AT+QSECWRITE="UFS:cacert.pem",1939,100 → Commands the modem to prepare for 1,939 bytes of data.
  • The modem will reply with CONNECT. You then stream the raw text of the certificate.
  • After sending the data, the modem returns OK.
Phase 3: SSL Configuration & MQTT Connection
This links the certificate to the MQTT client and performs the secure handshake.
  1. AT+QMTCFG="keepalive",0,60 → Sets MQTT keep-alive to 60 seconds.
  2. AT+QSSLCFG="cacert",2,"UFS:cacert.pem" → Assigns your uploaded cert to SSL context 2.
  3. AT+QSSLCFG="seclevel",2,1 → Sets security level to 1 (Verify Server).
  4. AT+QSSLCFG="sslversion",2,4 → Enables all SSL/TLS versions.
  5. AT+QSSLCFG="ciphersuite",2,"0xFFFF" → Enables all supported cipher suites.
  6. AT+QSSLCFG="ignorertctime",1 → Crucial: Tells the modem to ignore its internal clock (often wrong on startup) when checking cert expiration.
  7. AT+QMTCFG="SSL",0,1,2 → Binds MQTT Client 0 to use SSL Context 2.
  8. AT+QMTOPEN=0,"com",8883 → Opens a TCP connection on the secure port.
  • Wait for URC: +QMTOPEN: 0,0
  1. AT+QMTCONN=0,"abcd","mc60device","fghi" → Logs into the MQTT broker.
  • Wait for URC: +QMTCONN: 0,0,0
Phase 4: Data Transmission
  1. AT+QMTPUB=0,0,0,0,"Status" → Prepares to publish a message.
  • The modem will show a > prompt. You send your message followed by 0x1A (Ctrl+Z).
pls add
AT+QMTCFG=“VERSION”,0,1
