MC60 SDKMC60 SDK for development
How can I obtain the MC60 SDK for development?
i need the following details
AT command manual
EVB tool
Cloud access guide
GNSS protocol specification
Tools
Application guide
User guide
Hardware design manual
Driver
and example code and firmware .
I suggest you get all the information and tools by the purchase channel
If possible, please send me SDK 1.8 or higher specifically for the MC60.
Thank you.
Please provide your current detailed version
The version I’m using is 1.7, but it doesn’t support mqtt, unfortunately!
Thank you for sending the files.
However, in version 1.8, there’s a bug related to the callback function — Ql_Mqtt_Recv_Register(mqtt_recv); does not execute!
Do you have a version newer than 1.8, or a fixed version of it?
Hi. Can you send the latest MC60 SDK and Toolchain for me, too? I appreciate your help.
Thank you so much. Is it the latest version? I also need Toolchain for make and build. I appreciate your help.
The file package should contain the development guidelines. Please refer to it.
