Is it possible to keep the GNSS part of the MC60 module active (output nmea data through gnss tx/rx) while powering down the ME or putting it to sleep mode (or to any other power domain if any) ? I am using an EVB kit so I am not sure if I can test the same. Kindly advice if this is in any way related to the GNSS Stand-alone mode
Dear Hellraise007,
Thanks for you inquiry in Quectel forum. If you use our EVB+TEA module to test it, you can follow up the following guidance to let the ME enter into sleep mode while NMEA can output from the GNSS UART port. Thanks!
More information can get from the following document. Thanks!
Quectel_MC60-TE-A_User_Guide_V2.0.pdf (1.5 MB)
Where can i get the PowerGPS tool mentioned in the pdf? Also will it still output NMEA data if I turn off ME using AT+QPOWD=1?
