I’m using the MC60 chip with a PIC18F25K80 microcontroller, and I’m having some troubles using the ATGNSS commands.
I am specifically trying to use the AT+QGNSSRD command. Does anyone know which commands I need to use beforehand to configure the chip, and some guidance on how to read the values it sends?
Dear Sir,
If you want to use MC60 GNSS function, you just need to send AT command AT+QGNSSC=1 to enable GNSS engine, then after 5 seconds to check whether the module already get the position with AT+QGNSSRD? Thanks!
Please pay attention to that you should place GNSS antenna at open-sky or half open-sky environment. Thanks!
The following document just for your reference, please check. Thanks! Quectel_MC60_GNSS_AT_Commands_Manual_V1.2.pdf (939.9 KB)
