I uploaded program into the module
The netlight pin in the module doesn’t change his status.
You can check the debug print information to check whether the APP you uploaded have run normally. It is better to use the corresponding SDK code with the base firmware version. Thanks!
Hi , thank you for quick response.
When I download the firmware to module it’s shows successful message but not blink the LED and also i check with debug port with qcom software but it not shows any output.
Please check the module firmware version with ATI command, and the SDK version you used. And you can add dome print information in your code, then check the debug log in module debug UART port. Thanks!
HI,
I have the face same issue, When i send AT command it not send any response.
please help me.
