Hi Winnie,
First, sorry for the delay. I still have the same problem.
- The modem version is MC60ECAR01A07
- Yes - it is a TCP connection.
- Yes - I send a message from server and the module didn’t wake up.
- I use an osciloscope and when I send SMS or call to to modem I see the RI is changed.
When I send data from server - no change in the RI pin, although the modem takes more current from the power supply in the moments of sending data from server and also after I wake up the modem in other way - it receives the data I sent from server before.
- Attached the AT commands.
AT
ATE0
ATV1E0Q0
AT+IPR=115200
AT&W
AT+CMEE=2
AT+CGMM
Quectel_MC60E
AT+CGMR
Revision: MC60ECAR01A07
AT+CGSN
XXXXXXXXXXX
AT&C0
AT&D0
AT+QISDE=0
AT+CPIN?
+CPIN: READY
AT+CCID
+CCID: “XXXXXXXXXXX”
AT+QIKALIVE=0,600,10
AT+QINDI=1
AT+COPS=0
AT+CNMI=2,1,
AT+QRIMODE?
+QRIMODE: 0
AT+QINDRI?
+QINDRI: 1
AT+CMGF=1
AT+CMGD=1,4
AT+QICSGP=1,“XXXXXXXXXXX”,"",""
AT+CREG?
+CREG: 0,1
AT+CREG?
+CREG: 0,1
AT+CGREG?
+CGREG: 0,1
AT+QISTATE?
STATE: IP INITIAL
AT+QIMUX=1
AT+QIREGAPP
AT+QISTATE?
STATE: IP START
AT+QIACT
AT+QISTATE?
STATE: IP GPRSACT
AT+CMGL=“ALL”
AT+CMGD=1,4
AT+QISTATE?
+QISTATE: 0,"","",“INITIAL”
AT+QIDNSIP=0
AT+QIOPEN=0,“TCP”,“xx.xx.xxx.xx”,“xxxxxx”
AT+QISTATE?
+QISTATE: 0, “TCP”, “xx.xx.xxx.xx”, xxxxx,“CONNECTED”
AT+QISACK=0
+QISACK: 0, 0, 0
AT+QISEND=0,98
SEND OK
AT
AT+CREG?
+CREG: 0,1
AT+CREG?
+CREG: 0,1
AT+CSQ
+CSQ: 16,0
AT+QISTATE?
AT+CMGL=“ALL”
+QISTATE: 2,"","",“INITIAL”
+QISTATE: 3,"","",“INITIAL”
+QISTATE: 4,"","",“INITIAL”
+QISTATE: 5,"","",“INITIAL”
AT+CMGD=1,4
AT+QIRD=0,1,0,0
+QIRD: 0, 0, 0
AT+QISACK=0
+QISACK: 98, 0, 98
AT+QISEND=0,120
SEND OK
AT+QIRD=0,1,0,0
+QIRD: 21, 0, 21
