I have MC-60 module bought a year back. Tested them and was working fine. But I have bought the new one last week. The circuit and everything is same as the previous MC-60 but I am facing issues. My GPRS is not activating. I always get “+CGATT:0” when try to activate GPRS. And also I get error as “+CME ERROR=1” which says "No Connection to Phone ".
I am not getting what the error is. Please let me know
Dear Rohithadpad,
About your issue, it is better to provide your whole test AT log to us, then we can help you to solve it.
And you can check the difference between the old MC60 module and the new one, you can take a picture of the two modules, and check the difference in software with ATI command. Thanks!
Dear Rohithadppad,
Please follow up the below AT command sequence to provide your test AT log. Thanks!
ATI
AT+CREG?
AT+CGREG?
AT+CSQ?
AT+CPIN?
AT+COPS?
If the above command can return the correct value, it can prove that the module have attached the CS &PS network. And there is no need to send AT+CGATT=1 command. Thanks!
Dear Rohithadpad,
From the log you provided, the module still cannot attach the network, so it will be error when you send AT+CGATT=1.
Please make sure whether you have connect the antenna, and use the right SIM card that can support GSM, and also use AT+CFUN? to check whether the module RF function have turn on normally, it should be return 1. Thanks!
The right value should be as following:
AT+CREG? /AT+CGREG? should be return 0,1 or 0,5.
AT+CSQ? should be return 0`31,99.
AT+COPS? should be return as the following value.
