Docs state that QMTPUB has a tx limit of 4096 bytes, which I’ve tested and found to be true ![]()
Docs don’t mention if there’s any limit for QMTSUB/QMTRECV.
Is there a limit, and if so where is this documented?
Thanks!
-Dave
Thanks!
-Dave
Currently BG770 only supports direct output mode, QMTRCV has no restrictions
I’m finding that’s not the case.
So, clearly there’s some limit (similar to the modem’s 4k limit for QMTPUB).
I could experiment to find out what it is, but I’d prefer to hear the actual value from Quectel’s tech folks.
Additionally: Can you tell me why the modem doesn’t send me any indication that anything happened? Even a “too much data” response would be better than my having to time out because otherwise I’d be waiting forever for a response that will never come.
If I don’t set this, which is the default, msg_recv_mode 0 or 1?
I’m now explicitly setting AT+QMTCFG="recv/mode",4,0 but I still don’t receive the QMTRECV when the server sends >4k of JSON.
Is there something else I should be doing?
pls run and query
AT+QGMR
ATI
AT+CGSN
AT+QGMR?
BG770AGLAAR01A05_BETA240209A_01.200.01.200_BETA240209A
ATI
BG770A-GL
Revision: BG770AGLAAR01A05_BETA240209A
AT+CGSN
863593053696050
