M66 TLS MQTT problem
Hi everybody
i am using this module:
ATI
Quectel_Ltd
Quectel_M66
Revision: M66FCR01A02BT
i want to connec to :
test.mosquitto.org:8883
with tls seclevel:2
this is my commands :
>AT+CPIN?
>AT+CPIN?
+CPIN: READY
>AT+CREG?
>AT+CREG?
+CREG: 0,1
>AT+CGREG?
>AT+CGREG?
+CGREG: 0,1
>AT+QIMODE?
>AT+QIMODE?
+QIMODE: 0
>AT+QICSGP?
>AT+QICSGP?
+QICSGP: 1
>AT+QIDNSIP?
>AT+QIDNSIP?
+QIDNSIP: 1
>AT+QIDNSIP=1
>AT+QIDNSIP=1
AT+QSECWRITE="RAM:cacert.pem",1452,100
CONNECT
+QSECWRITE: 1452,2057
AT+QSECWRITE="RAM:client.pem",1289,100
CONNECT
+QSECWRITE: 1289,3a40
AT+QSECWRITE="RAM:user_key.pem",1704,100
CONNECT
+QSECWRITE: 1704,5e3c
>AT + QSSLCFG = "cacert", 2, "RAM:cacert.pem"
>AT + QSSLCFG = "clientcert", 2, "RAM:client.pem"
>AT + QSSLCFG = "clientkey",2, "RAM:user_key.pem"
>AT + QSSLCFG = "seclevel", 2,2
>AT+QSSLCFG="sslversion",2,4
>AT+QIFGCNT?
+QIFGCNT: 0,0
>AT+QIFGCNT=0
>AT+QIMUX?
+QIMUX: 0
>AT+QISTAT
>AT + QIDEACT
>AT + QIDEACT
DEACT OK
>AT+QICLOSE
>AT+QICSGP=1,"apn"
>AT+QIREGAPP
>AT+QIREGAPP
>AT+QIACT
>AT+QIACT
AT+QIACT
>AT+QILOCIP
>AT+QMTCFG="VERSION",0,1
>AT+QMTCFG="SSL",0,1,0
>AT+CMEE=2
close old connection
>AT+QMTCLOSE=0
AT+QMTCLOSE=0ERROR
>AT+QMTOPEN=0,"test.mosquitto.org",8883
+QMTOPEN: 0,2
what is my mistake?
is timing between commands is important?
i am using python lang with pyserial lib to connect module with serial port .
is this important?
BTW: i could connect o same server with port 1883 without tls
i think problem is with tls files
Hi
This is because the last mqtt connection was not closed, I see that your log has “AT+QMTCLOSE=0ERROR”. A high probability is caused by the failure to close the old connection
